# Android App
The openHAB Android application is a native client for openHAB, compatible with phones and tablets. The app follows the basic principles of the other openHAB UIs, like Basic UI, and presents your predefined openHAB sitemap(s) (opens new window) and other UIs, like Main UI.
Get it on Google Play Get it on F-Droid
Demo Overview Widget Overview Main UI
# Getting Started
On first start the app tries to discover your openHAB server. This will only work on local networks and when the server doesn't enforce authentication. If it fails, you can click on Go to settings and manually enter the server settings.
  • IP address: http://192.168.1.3:8080
  • Local hostname: http://openhab:8080 (depending on your network the suffix .local needs to be added to the hostname)
  • Remote domain name: https://myopenhab.org for an openHAB cloud account with myopenHAB (opens new window)
# Features
# Permanent Deployment
To run your voice command rule please make sure that Default Human Language Interpreter is set to Rule-based Interpreter (http://openhab:8080/settings/services/org.openhab.voice (opens new window)) and that the correct Item is selected at Other Services => Rule Voice Interpreter => Voice Command Item (http://openhab:8080/settings/services/org.openhab.rulehli (opens new window)).
If you have more than one device, it's recommended to fill out the device identifier on the main settings page. This prefixes every item name, e.g. with the Prefix John the item AlarmClock becomes JohnAlarmClock. This way you don't have to change every item name.
  • Event based (Alarm clock and call state)
  • Schedule based (Everything else)
# Alarm Clock
Example item definition:
rule "Alarm Clock"
    Time is AlarmClock
# Limitations
The openHAB app uses the internal Android API AlarmManager (opens new window) to get the next alarm time. Some apps use this API (e.g. the stock calendar app) for other purposes, e.g. scheduling notifications. Therefore the openHAB app may send invalid alarm times to the server. To circumvent this the alarm times set by some apps are blocklisted in the openHAB app and it'll send UNDEF instead. It's not possible to read the time after the next.
# Call State
Example rule:
rule "Call State"
    Item CallState changed
        // No call activity
# Battery Level
Example rule:
rule "Battery level"
    Item BatteryLevel changed
        // Battery level is low
# Charging State
The charging state can be send to a String Item that contains the charger type or to a Switch Item, which is ON when charging, OFF otherwise. The app determines the Item type automatically, so it's not required to configure the Item type in the app.
// or
rule "Charging state"
    Item ChargingState changed
# Wi-Fi Name (SSID)
Example rule:
rule "Wi-Fi name"
    Item WifiName changed
# Bluetooth devices
Send a | separated list of MAC addresses of connected bluetooth devices.
Example rule:
rule "Bluetooth devices"
    Item BluetoothDevices changed
        // No device is connected
# DND Mode
Example rule:
rule "DND mode"
    Item DndMode changed
        // DND mode is unknown
# Gadgetbridge Device Actions
Example rule:
rule "Gadgetbridge"
    Item Gadgetbridge changed
# Device identifier
# Tasker Action Plugin
Variables can be selected as state after they have been created in the task. The variable %httpcode is returned by the plugin and contains the HTTP code returned by the server.
Error Code Description
10 Tasker plugin is disabled
11 The app couldn't establish a connection
> 1000 A connection was established, but an error occurred. The error code is 1000 + the HTTP code, e.g. 1401 means Unauthenticated (opens new window).
# Device Controls
Device Controls
openHAB supports the device controls introduced in Android 11: https://developer.android.com/develop/ui/views/device-control (opens new window) When using a semantic model (opens new window) the location and/or equipment name can be shown in the tiles. The icon in the tiles is based on the semantic class of the Item.
You can configure the page that is opened when you long-press a tile. Create an "Android App: Device Controls" metadata on an Item with a link without the host to a Sitemap (e.g. /basicui/app?w=0202&sitemap=demo) or MainUI (e.g. /locations).
# UI command Item
Similar to the UI command Item in Main UI (opens new window) you can use a String Item to control the Sitemaps. Whenever the configured Item receives a command, the app reacts on this command. Examples:
  • Sending the command navigate:/basicui/app?w=0003&sitemap=foo opens a subpage of the Sitemap foo. To get this URL, open the Sitemap in Basic UI and copy the URL after the hostname.
  • Sending the command notification:Hi there shows a popup with this text.
All commands except the popup: command are supported by the app.
# Multi server support
  • Display Sitemaps, Main UI and HABPanel
  • Voice commands launched from in-app (sent to active server) and from widgets (sent to primary server)
  • Show a list of recent notifications
  • Sitemap shortcuts on the home screen
  • Shortcuts for HABPanel, notifications and voice command
  • Item widgets on the home screen
  • Quick tiles
  • NFC tags
  • Push notifications
  • Send device information to openHAB
  • Tasker plugin
# Help and Technical Details
  • Notifications are only fetched every 6 hours by default. It uses the same schedule than Send device information to openHAB.
  • Read status aren't synced between devices.
  • The maximum number of messages that can be received during one fetch is limited to 20.
# I have issues with Main UI or HABPanel
The app uses the WebView component of the Android system to render all UIs except Sitemaps. If something is rendered different than in the browser on your mobile device, you can try to update the default WebView implementation (https://play.google.com/store/apps/details?id=com.google.android.webview (opens new window)) or switch to a different implementation. To do so, enable developer settings options (opens new window) then go to the developer settings and select "WebView implementation".
# Chart loading is too slow
Generating charts can be taxing to the server. If you experience slow chart loading times and your server isn't powerful, open Settings and disable High resolution charts to improve loading times.
# Icons look pixelated
# Trademark Disclaimer
