# Sitemaps
    Frame label="Date" {
        Text item=Date
    Frame label="Demo" {
        Group item=Heating
        Text item=LR_Multimedia_Summary label="Multimedia [%s]" staticIcon="video" {
            Slider item=LR_TV_Volume
# Concepts
# Elements
Sitemaps are composed by arranging various user interface elements. A set of different element types supports a user-friendly and clear presentation. The example above contains Frame, Text and Switch elements among others. Elements present information, allow interaction and are highly configurable based on the system state. One line of Sitemap element definition produces one corresponding UI element. As shown in the example, each element generates a descriptive text next to an icon on the left side and a status and/or interaction elements on the right.
# Nested Elements
# Frames
By encapsulating elements with curly brackets, multiple elements can be nested inside or behind others. The Frame element type is often used in combination with element blocks. Frames are used to visually distinguish multiple elements of the same topic on one interface page.
    Text item=Date
    Group item=Heating
When you are using Frame elements at one hierarchy level of your sitemap, you can not use any other element type besides Frame. Different elements can be used on the previous or next hierarchy level.
# Blocks
When using code blocks behind other element types such as Text or Group, these UI elements will, in addition to their normal function, be links to a new view, presenting the nested elements.
# Special Element 'sitemap'
    [all sitemap elements]
# Parameters
A certain set of parameters can be configured to customize the presentation of an element. In the shown example item, label and valuecolor are parameters. Almost all parameters are optional, some are however needed to result in a meaningful user interface. To avoid very long or unstructured lines of element definition, parameters can be broken down to multiple code lines.
# Dependencies
A typical sitemap contains dozens of individual elements. A system state and possible interactions are however often closely dependent. openHAB supports these dependencies by providing parameters for dynamic behavior. Be sure to check out the Dynamic Sitemaps chapter.
# Element Types
Element Description
Buttongrid Renders a grid containing buttons.
Button Renders a button inside a Buttongrid that is used to send commands to a given Item.
Colortemperaturepicker Allows the user to choose a color temperature from a white color gradient.
Input Renders an input field for text or numbers.
Text Renders an Item as text.
    • icon chooses the icon to show next to the element, more details.
  • When an Item is defined, you have the opportunity to assign a label and/or an icon at that point. If no label or icon are specified in the Sitemap, then the label and/or icon you assigned to the Item will be displayed. Setting a value for label or icon or staticIcon of a Sitemap element will override the values defined for the linked Item. There is an exception for chart, image, video, mapview and webview Sitemap elements: the item label is ignored and only the value of label is considered for the label.
  • The parameters icon and staticIcon are exclusive; both allow choosing the icon to show next to the element but staticIcon also indicates not to try to create a dynamic icon (using the current state of a linked item). The value of these two parameters can optionally be enclosed in double quotes.
It has to be considered that if the label defined in a Channel or an Item contains text and state, these representations have to be overwritten separately in the Sitemap. In the following example an Item which has a label and state defined is overwritten.
    Frame label="Temperature" {
UoM = Units of Measurement
# Element Type 'Frame'
Frame [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] {
    [additional sitemap elements]
    //# and so on...
# Element Type 'Default'
Default item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
Such an implicit Slider element will have the releaseOnly parameter set. Its behavior is therefore to send the new value only when the slider is released. It will also have the switchSupport parameter set.
# Element Type 'Text'
Text [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
Text item=Temperature label="Livingroom [%.1f °C]" staticIcon=temperature
# Element Type 'Group'
Group item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
# Element Type 'Switch'
Switch item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [mappings="<mapping definition>"]
  • mappings comes as an array of value-to-string translations, documented further down. Without the mappings parameter, user interfaces will present an On/Off Switch, if mappings are given, several buttons with label or icon will be rendered and each button can behave either as a click button or as a press and release button.
Switch item=LR_CeilingLight label="Ceiling Light" icon=light
# Element Type 'Buttongrid'
Buttongrid [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [buttons="<Button definition>"]
A Buttongrid represents a grid of buttons and enables commands to be sent to an Item.
This is a typical element for simulating a remote control, for example.
  • item commands triggered by the buttons are sent to the item identified by this parameter. This parameter is only required if the buttons parameter is also used.
  • label if set, a header row will be displayed containing this label and the icon.
  • buttons defines the position of each button within the grid and the command associated with each button; provided as an array.
When buttons are defined by the buttons parameter, all buttons are linked to the same Item and a command can only be sent to that item when one button is clicked (and not when it is pressed and released); buttons never appear as selected, they do not display the current state of the linked Item. The buttons parameter is optional, using Button elements as children is now the best option because it provides more functionality, but this option is not yet supported by all sitemap UIs.
Buttons syntax:
buttons=[row_1:column_1:command_1="description_1", row_2:column_2:command_2="description_2"=<iconname>, ...]
The buttons can be defined in any order, their position in the grid is defined by a row index and a column index. The top left position is row index 1 and column index 1. The grid must not exceed 12 columns so the maximum allowed column index is 12 columns. It is not mandatory to define a button in all grid cells. The user interfaces will automatically determine the grid size so that all buttons are presented.
The content of each button can be text but also an icon; the icon will be used by default if provided.
Buttongrid label="Remote Control" staticIcon=screen item=RemoteControl buttons=[1:1:POWER="Power"=switch-off , 1:2:MENU="Menu" , 1:3:EXIT="Exit" , 2:2:UP="Up"=f7:arrowtriangle_up , 4:2:DOWN="Down"=f7:arrowtriangle_down , 3:1:LEFT="Left"=f7:arrowtriangle_left , 3:3:RIGHT="Right"=f7:arrowtriangle_right , 3:2:OK="Ok" , 2:4:VOL_PLUS="Volume +" , 4:4:VOL_MINUS="Volume -" , 3:4:MUTE="Mute"=soundvolume_mute]
Presentation of the Buttongrid element in BasicUI
# Element Type 'Button'
Button item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] row=<row> column=<column> [stateless] click=<cmd> [release=<cmd>]
Such an element is only accepted as a child of a Buttongrid element. You can choose between stateful or stateless behavior and between click or press & release behavior. When a button is pressed and/or released, the associated command is sent to the linked Item.
  • item commands triggered by the button are sent to the item identified by this parameter.
  • label if set, it defines the text to display in the button. If not present, the value of the command (click parameter) is used as text.
  • icon / staticIcon if set, it defines the icon to display in the button. If not present, the button will contain a text. The icon can be dynamic by defining rules in the icon parameter.
  • row / column define the position of the button in the grid. The top left position is row index 1 and column index 1.
  • stateless sets the button to stateless; by default, a button is stateful.
  • click / release a button is a click button by default, the command to send to the item is defined by the click parameter. Press & release behavior is possible by setting the click and release parameters.
Label and icon color can be dynamic using the labelcolor and iconcolor parameters. Visibility of the button can be dynamic using the visibility parameter. Care must be taken to define visibility rules such that this does not result in several buttons being visible at the same position in the grid.
Buttongrid label="Remote Control" staticIcon=screen {
    Button row=1 column=1 item=RemoteControl label="Power" staticIcon=switch-off stateless click=POWER
    Button row=1 column=2 item=RemoteControl label="Menu" stateless click=MENU
    Button row=1 column=3 item=RemoteControl label="Exit" stateless click=EXIT
    Button row=2 column=2 item=RemoteControl label="Up" staticIcon=f7:arrowtriangle_up stateless click=UP
    Button row=4 column=2 item=RemoteControl label="Down" staticIcon=f7:arrowtriangle_down stateless click=DOWN
    Button row=3 column=1 item=RemoteControl label="Left" staticIcon=f7:arrowtriangle_left stateless click=LEFT
    Button row=3 column=3 item=RemoteControl label="Right" staticIcon=f7:arrowtriangle_right stateless click=RIGHT
    Button row=3 column=2 item=RemoteControl label="Ok" stateless click=OK
    Button row=2 column=4 item=RemoteControl label="Volume +" stateless click=VOL_PLUS
    Button row=4 column=4 item=RemoteControl label="Volume -" stateless click=VOL_MINUS
    Button row=3 column=4 item=RemoteControl label="Mute" staticIcon=soundvolume_mute stateless click=MUTE
# Element Type 'Selection'
Selection item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [mappings="<mapping definition>"]
# Element Type 'Setpoint'
Setpoint item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] minValue=<min value> maxValue=<max value> step=<step value>
# Element Type 'Slider'
Slider item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [switchSupport] [minValue=<min value>] [maxValue=<max value>] [step=<step value>] [releaseOnly]
    • Android app: If specified, a short press on the item row (except the slider itself) switches the item ON or OFF.
  • releaseOnly: If specified, the new value is only sent on releasing the slider. Otherwise values are sent while sliding.
# Element Type 'Colorpicker'
Colorpicker item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
This element is a combined control for something like a rgb or rgbw light where you can adjust brightness as well es the color hue. The down-button decreases brightness to zero and switches the light off. The up-button sets brightness to full but keeps the previous color (hue). The middle button opens an overlay to fine-tune your color when you click on it. In the overlay, a color wheel lets you pick the hue and a slider allows to set the brightness. The content of this middle button can also show what is the current color.
Colorpicker item=LR_LEDLight_Color label="LED Light Color" staticIcon=colorwheel
# Element Type 'Colortemperaturepicker'
Colortemperaturepicker item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>]
This element is a control for something like a rgb or rgbw light where you can adjust the color temperature. The button opens an overlay to fine-tune your color temperature when you click on it. In the overlay, a white color gradient lets you pick and set the color temperature. The content of this button can also show what is the current color temperature.
  • minValue and maxValue limit the possible range of the value (both included in the range).
Colortemperaturepicker item=LR_LEDLight_ColorTemp label="LED Light Color Temperature" staticIcon=colorwheel
Presentation of the Colortemperaturepicker element in BasicUI
# Element Type 'Input'
Input item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [inputHint="<inputHint>"]
This element allows entering of text, numbers and dates/times and updating the underlying items. This can for example be useful to update manually collected meter readings and storing the information in an item. Text, number or number with unit values and dates/times can be updated in the respective item types. Formatting in the label parameter will format the current value, but the value update will be as entered in the field. E.g. this makes it possible to use formatting like [%.0f %unit%] to show the current value without fractions, but still update to whatever is entered.
  • inputHint will give a hint to the user interface to use a specific widget adapted to a specific use. Valid values for the parameter are text, number, date, time and datetime. Support of these widget types vary by user interface and/or browser.
Note that this element type may not be supported on all user interfaces that support sitemaps.
Input item=Meter_Reading label="Meter [%.0f %unit%]" staticIcon=energy inputHint="number"
Presentation of the Input element in BasicUI
# Element Type 'Webview'
Webview item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] url="<url>" [height=<heightvalue>]
# Element Type 'Mapview'
Mapview [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [height=<heightvalue>]
# Element Type 'Image'
Image [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] url="<url of image>" [refresh=xxxx]
# Element Type 'Video'
Video [item=<itemname>] [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] url="<url of video to embed>" [encoding="<video encoding>"]
# Element Type 'Chart'
Chart item=<itemname> [label="<labelname>"] [icon=<iconref>] [staticIcon=<iconref>] [refresh=xxxx]
period=xxxx [service="<service>"] [legend=true/false] [forceasitem=true/false] [yAxisDecimalPattern=xxxx]
[interpolation=xxxx]
  • period is the scale of the time axis. The time axis can be either entirely in the past ending at the present time, entirely in the future starting at the present time, or partly in the past and partly in the future around the present time. To do this, the value can be composed of two parts separated by the "-" character, the value before the "-" is then the scale in the past and the value after the "-" is the scale in the future. Valid values before and after the central character "-" are h, 2h, 3h, ..., D, 2D, 3D, ..., W, 2W, 3W, ..., M, 2M, 3M, ..., Y, 2Y, ... and any valid duration following the ISO8601 duration notation such as P1Y6M for the last year and a half or PT1H30M for the last hour and a half. If only a period is provided, i.e. without the final "-" character or without anything after the "-" character, only a period in the past is taken into account.
  • forceasitem is used to show the value of a Group instead of showing a graph for each member (which is the default).
  • yAxisDecimalPattern is used to format the values on the y axis. It accepts DecimalFormat (opens new window). For example with #.## a number has to decimals.
  • interpolation is used to change how the line is drawn between 2 datapoints. By default, a horizontal line (step) will be drawn between 2 datapoints of Switch or Contact items. All other item types will have a line (linear) connecting the datapoints. With the linear or step value for this parameter, this default behaviour can be changed.
# Mappings
Mapping syntax:
mappings=[value_1="description_1", value_2="description_2"=<iconname>, value_press:value_release="description_3", ...]
mappings=[ON="Mic On"=material:mic, OFF="Mic Off"=material:mic_off]
mappings=[ON:OFF="On"]
In the fifth example above, user interfaces will display buttons using the provided icon rather than the provided description. Icons are usable in Switch element but ignored in Selection element.
In the sixth example above, as there are 2 commands provided separated by a colon, user interface will consider a press and release behavior, the first command (ON in the example) is sent to the item when the button is pressed and the second command (OFF in the example) is sent when the button is finally released. This behavior is only applicable for a Switch element.
# Dynamic Sitemaps
# Visibility
Visibility syntax:
visibility=[item_name operator value, item_name operator value AND item_name operator value, ... ]
You can set as many conditions as you want.
A condition can be a single comparison or a combination of several comparisons all separated by the AND operator. A condition including the AND operator will be considered as true if all individual comparisons are considered as true. Of course, it is possible to reference a different item in each comparison.
  • equal to ==, unequal to !=
  • less than <, greater than >
Expressions are evaluated from left to right. The Item will be visible if any one of the conditions is evaluated as true, otherwise it will be hidden.
Switch item=CinemaLight label="Cinema light" visibility=[TV_Power==ON]
Switch item=LawnSprinkler visibility=[Day_Time=="Morning" AND Temperature>19]
In the third example above, a control for a lawn sprinkler will be visible if it is Morning, OR if it is Afternoon, OR if the temperature is above 19 °C. In the fourth example above, multiple conditions are combined, a control for a lawn sprinkler will be visible if it is Morning AND if the temperature is above 19 °C.
# Label, Value and Icon Colors
Colors can be used to emphasize an items label or its value based on conditions. Colors may be assigned to either the label or the value associated with an Item. The icon may be tinted depending on the state as well.
Label, Value and Icon Color Syntax:
labelcolor=[item_name operator value = "color", item_name operator value AND item_name operator value = "color", ... ]
valuecolor=[item_name operator value = "color", item_name operator value AND item_name operator value = "color", ... ]
iconcolor=[item_name operator value = "color", item_name operator value AND item_name operator value = "color",... ]
You can set as many conditions as you want, along with a color for each condition.
If only a color is specified, that condition is considered as true and that color will be used. Providing only a color can be used as a last condition to set a default color that will be used when none of the other previous conditions were true.
The comparison operators for labelcolor, valuecolor and iconcolor are the same as for the visibility parameter.
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[22="green"] iconcolor=[22="green"]
Text item=Temperature labelcolor=[>0="blue"] valuecolor=[==22="green"] iconcolor=[==22="green"]
Text item=Temperature labelcolor=[Temperature>0="blue"] valuecolor=[Temperature==22="green"] iconcolor=[Temperature==22="green"]
The line below illustrates setting a default color (gray) and how to combine multiple comparisons with an AND operator:
Text item=NumberItem labelcolor=[>0 AND <50="yellow", >=50="green", "gray"] valuecolor=[>0 AND <50="yellow", >=50="green", "gray"] iconcolor=[>0 AND <50="yellow", >=50="green", "gray"]
Note that expressions are evaluated from left to right; the first matching expression determines the color. If the order of the expressions was reversed, the color assignment would not work. Note also, the effect of omitting Temperature and the comparison operator in the expression 0="white" (as compared to ==0="white").
maroon
#800000
red
#ff0000
orange
#ffa500
olive
#808000
yellow
#ffff00
purple
#800080
fuchsia
#ff00ff
pink
#ffc0cb
white
#ffffff
lime
#00ff00
green
#008000
navy
#000080
blue
#0000ff
teal
#008080
aqua
#00ffff
black
#000000
silver
#c0c0c0
gray
#808080
gold
#ffd700
There are also the following keywords that can be used as colors:
Color Name Note
primary Primary theme color
secondary Secondary theme color
itemValue The state of the linked Color item
# Icons
openHAB allows a set of icons to be assigned to the different states of an Item and therefore to be presented in a Sitemap. This first way of proceeding only considers the current state of the linked item and requires the use of icons provided by openHAB and a particular syntax of icon names. Please refer to the documentation on Item configuration for details.
There is also a more powerful way to define a dynamic icon based on the states of different items and allowing you to attach any type of icon regardless of its source (not restricted to icons provided by openHAB).
The icon parameter can be used to provide conditional rules.
Extended icon syntax:
icon=[item_name operator value = icon, item_name operator value AND item_name operator value = icon, ... ]
You can set as many conditions as you want, along with a reference to an icon for each condition.
Conditions are evaluated from left to right; the first matching condition determines the icon. If only a reference to an icon is specified, that condition is considered as true and that icon will be used. Providing only a reference to an icon can be used as a last condition to set a default icon that will be used in case any of the other previous conditions is true.
The comparison operators are the same as for the visibility parameter.
Text item=TemperatureTrend icon=["UP"=f7:arrowtriangle_up, "DOWN"=f7:arrowtriangle_down, f7:arrowtriangle_right]
Text item=TemperatureTrend icon=[=="UP"=f7:arrowtriangle_up, =="DOWN"=f7:arrowtriangle_down, f7:arrowtriangle_right]
Text item=TemperatureTrend icon=[TemperatureTrend=="UP"=f7:arrowtriangle_up, TemperatureTrend=="DOWN"=f7:arrowtriangle_down, f7:arrowtriangle_right]
        Text item=Date
        Group item=Heating
Explanation:
