# Armbian
# What is Armbian?
  • comes in desktop, minimal or server variant,
  • has clean and highly optimized user space,
  • is Ubuntu and Debian compatible,
  • is supported with vibrant community,
  • comes with a powerful SDK which allows reproduction and customization,
  • supports many 3rd party wireless drivers with advanced functionalities,
  • supports Docker, disk encryption, Wireguard VPN any many other features.
openHAB will run on any Armbian supported hardware (opens new window) but it is recommended to choose boards that have at least:
Armbian
# Supported images
# Setup
First Steps:
  1. Prepare Armbian as usual - login as root / 1234, change root password, create username. You don't need to perform any other steps (opens new window).
  2. Update
sudo apt-get update
sudo apt-get upgrade
  1. Run armbian-config
sudo armbian-config
Armbian config System and 3rd party software Softy
Select OpenHAB2 (old version) or OpenHAB3 with SPACE and press ENTER
Openhab
Wait 5 to 10 minutes depending on your hardware. During this time you can leave armbian-config and check if installation was successful by checking what openhab is doing on the system:
sudo htop -u openhab
Observe activities with htop
# Help
In case you run into a problem that is board hardware related, please use the Armbian Community forums (opens new window) or Armbian bug reporting form (opens new window).
