# Karaf debugging
This procedure allows for testing and debugging while running openHAB with Apache Karaf (opens new window).
# Limitations of the demo project
The org.openhab.demo.app project is great for testing and debugging in most circumstances, but not everything behaves identically to that of a "real" openHAB installation, which uses Apache Karaf (opens new window).
Karaf provides a runtime environment with a lot of built-in functionality that isn't available when running the demo project.
As a consequence, some things function slightly differently or aren't available at all, such as loading of KAR add-ons.
# Preparation
If you haven't already, clone the openhab-distro repository (opens new window).
Make sure that the bundles you want to test or debug have been installed in your local Maven repository, using mvn clean install -pl :<bundle coordinates> or similar.
Any bundles not found in your local Maven repository will be downloaded in their latest snapshot version.
If you want to test or debug an older version, you must therefore build and install everything into your local Maven repository first.
# Building
From the openhab-distro folder, run
mvn package -nsu -Pdev
Do not use mvn install since it's not possible to install a folder into the local Maven repository.
-nsu (--no-snapshot-updates) prevents Maven from downloading "updated" artifacts, making sure that those from the local Maven repository are used.
# Launching
The result of the build can be found in openhab-distro/distributions/openhab/target/openhab-<version>.
From this folder, you can launch openHAB under Karaf by running start or start_debug.
The difference between the two is that start_debug will also allow a debugger to be attached to port 5005.
The console from which you did this will now become the Karaf console and will accept any normal Karaf command.
You can now open this openHAB installation in your browser via http://localhost:8080/ (opens new window).
To stop the installation, run system:shutdown or logout from the Karaf console.
# Debugging
Make sure that you launched openHAB using start_debug, and attach the debugger of your IDE to port 5005.
Your IDE needs to have access to the source code that you want to debug.
The exact procedure for setting up remote debugging is specific to each IDE.
# Eclipse
Create a new "Debug Configuration" for remote debugging:
Once that is done, click Debug and it should connect to the running openHAB instance.
Nothing will happen initially, you must set breakpoints and wait for the code to reach one of them.
# IntelliJ
Follow step 3 from Debug your addon.
# Visual Studio Code
Follow steps 8 to 10 from Steps for each Bundle.
# Rebuilding
If you modify any code, the bundle that has been modified must first be rebuilt using mvn clean install.
Make sure that the Karaf console is stopped, and build the Karaf new installation using
If you use clean as well, the whole openHAB installation will be wiped, and you must configure a user, go through the startup wizard and repeat any other configuration steps.
It's therefore recommended to just use package without clean.
The dev profile will delete the runtime subfolder with each build, so that the Karaf cache is deleted and your newly built code will be used, while retaining the configuration of the installation.
